Mk5 Can be used yes. Its the rear section that is "problem" since IT gets Wider longer up than mk5, so lower part of sill is same, but if ieed to cut higher up, then need to fabricate.
here i have used mk5, so you see that lower part is same, but you see the rear quater is diffrent then normal if go futher up.
A decent panel beater or fabricator can make them fit easily enough. If you've not taken then off yet be prepared for the horrors that might lurk behind.
