BT vs ST loom
  • BT vs ST loom
    I know engine loom is different.
    Is the car loom, especialy engine bay loom same on BT and ST?
    Does ST use separate loom for engine like BT or is it incorporated in the rest of engine bay loom?
    ST uses a serperate engine loom
      If you're looking for a mint condition LHD engine loom, I have one hanging in my garage. Never cut / repaired. All connectors always had grease in them, no corrosion etc..
        I always thought the ST (T25) had the engine loom integrated into the cars harness
          As above engine loom plugs into main loom.
          John
            Do you maybe know if this could be a complete loom.
              top pic looks like a dash loom,the middle pic looks like the loom from the engine bay,bottom pic could be the main car loom maybe as you can see the door connectors it looks a nightmare what ever it is what are you actually after? big t or small t or trying to adapt the two or something?
                heres my small t engine loom if it helps at all?
                  Does not look a complete ST loom.. Can't see engine connectors, EDIS connector or EEC connector.
                  John
                    I have a small t and it looks like someone tried to convert it to BT but never finished, just started and cut some (most) wires going to ecu connector. Luckly all wires are there and only engine bay ones are messed, everything else is untouched. Complete engine bay loom is unwraped but it looks like everything should be there. I haven’t came to that part yet but i was thinking it would be the easiest way to buy complete engine bay and engine loom and fit it.
                    The only problem is that i don’t know how does engine bay loom looks like and when i find one Sellers cannt tell if it is or not complete.
                      I spot the EEC connector in pic 2 now.
                      Lay the loom out flat, as it is difficult to tell from the tangle.
                      John
                        nick you got a pic where these plug in.im not using them anyway but would be good to see where they originally went as mine has been removed.
                          which plugs you mean?
                            the two main plugs that would separate it from the loom.i read somewhere the nearside wheel arch but couldn't find them
                              I am waiting for better ones, here are of the other loom i found, these are even worse;
