where was the escort cosworth made
  • where was the escort cosworth made
    as above was it made in uk
    and is it seam welded as im sure it is
    Karmann in Germany built them i believe.
      and the engine where was that made please and thanks
        thats right as chopper said in germany, and i may be wrong but northampton england had a factory built cosworth engines and also some in america.. . sure others will correct me if i am wrong on the later.
          As above...believe the cars were built in Karmann Germany, and Cosworth are based in Northampton UK.
          Also, am I right in thinking that the only "Cosworth" part of the engine is the cylinder head? The bottom end was all original Ford? Not 100% sure on that...
            At Cosworth's Wellingborough Factory (not far from the Northampton HQ).
              I think they were built in two or three different factories in germany. By Karmann as stated above. I believe mine was built in Genk.
                Originally posted by Dave H View Post
                .......I believe mine was built in Genk.
                More likely to be Rheine (at the Karman works).
                To confirm, check your VIN code here: http://www.btinternet.com/~madmole/vindecoder.html
                Your VIN Decoded
                The VIN code WFOBXXGKABPDXXXXX breaks down as
                Assembly Plant: Rheine - Karman (Germany)
                  Mines being built in my garage ............ just trying to rectify the cock ups they made in Germany
                  good tool that VIN code checker
                  Manufacturer Identifier: Ford Werke A.G. (Germany)
                  Body type: 3 Door Hatchback
                  Line: Ford Germany (Own Assembly)
                  Model: Escort/Orion
                  Year: 1995 (some codes are used for more than one year)
                  Month: December
                  Production Sequence: 82911
                  RS500 8 injector T4 515 BHP
                  Restored, Built and Setup by M.A.S Tuning
                  The Never Ending Story......
                  HERE
                    Your VIN Decoded
                    Thats a handy tool. It does indeed come back as Rheine - Karman works.
                      Genk is in Belgium mate
                      Sierra Cosworths were built there.
                      1992 Gloss Black Ford Escort RS Cosworth
                        was they seam welded
                          They are not seam welded
                            well what r they as i thought they was a stronger shell
                              The shell is more rigid than the sierra torsionally i.e has extra points welded to the struts etc which reduces the body flex.
                              Andy
