Originally posted by s7evo
View Post
3 spoke steering wheel
Originally posted by The Radman View Posti used to have one of them and the 4 spoke one,got them from a guy in germany,he used to sell quite a few new ones,think he must have worked at fords or something,the hardest part is finding the correct boss for them as the hole pattern on the wheels is unique to fords as far as i know
mine used a genuine ford one and went on no probs,it was on my momo benneton wheel too so the fordfits a few wheels too aswell as the other RS/Wolf ones.
Originally posted by s7evo View PostYeah same wheel, feels chunkier then the usual ones.Mine had an airbag and was not striaghtforward to change. I bought the boss for a non airbag car for my RS wheel. Ill have to change the top end of the rack for it to fit.
Originally posted by matt cooke View PostSo what exactly is involved in fiting the above wheel to an airbag escos?
it helps if you can find one with ign key as you will need this to remove the ign barrel so you can fit your own one
also get the top and bottom cowlings and the orange bonnet pull handle as these are slightly diff
you then need a suitable boss and your new wheel,job done
Why do you have to change the colum? I fitted a momo steering wheel to my old escort, just took the air bag off, measured the resistance and fitted a resistor in the plug tucked that up inside the boss and bolted it all up, and everything worked fine or is there something else different on a escos to a standard escort?
