What ratios are available for the Group A / WRC 9" rear diff ?
9 inch rear diff - ratios ?
hi mateOriginally posted by Panza View PostWhat ratios are available for the Group A / WRC 9" rear diff ?
ford offered 3.083 /3.250/ 3.417 / 3.636 / 3.818 / 3.9 / 4.091 / 4.273 / 4.444 / 4.667 / 4.889 / 5.111/ the ratio 4.8 was only used on the last WRC cars all the spec's are taken from the ford motor sport boreham books for you
i hope this helps
It has to be matched - otherwise you will screw the centre VC. You do this with the relevant drop gears on the frontOriginally posted by Panza View PostWhich ratios are useable on the front with the 3.636 rear ?
Or more general: What is the max difference in ration front to rear ?
Yes, I agree they have to be matched, but HOW closely ?
Look at these calculations (correct this time I hope). It seems to me that 5 rpm or 7 rpm is less than what would cause the centre diff to start locking up.Attached Files
