I've started to replace the radiator on my ST Escort, the air con brackets had corroded off. Is it worth swapping the water pump whilst I'm there?
There's no leaks and I'm sure it was running fine but as it is the access is pretty good.
Any recommendations for a supplier? Need thermostat as well the gaskets, thinking Burton??
Also does the bottom pulley need to come off to remove the cam cover?
Steve
Steve
