chips, mapping
  • chips, mapping
    undergoing gt30 conversion on my escos but wanting to know were is best place to get a chip for it. will i need a chip making specificaly to suit my engine spec? then if i get one does it need mapping aswell? wot benefits does mapping have- just wen my car was stage 3 with chip and then had it mapped twice for the money spent wasnt much diffrence? bit lost with all this lot. . .
    you would want that live mapping mate, a easy well know "same across the range" stage chip is ok
    stage 1,2,3 yeah all near enough the same and will be ok
    but when you start changing to big turbos, cams ect then you need to have it done properly
    the advantage of a live map is, your fuel economy and power will be better as your fulling at every point will be 100% and will get the most out of the engine
    rather than being "thats near enough"
    jim
      well said that man.
      Gaz, what ecu will you be running on?
        thanks j1mbo well explained mate, i have msd chip at min wich was for my old t34 and siemens 55s, now im using 83lb injectors wud that chip still be ok just require a live map? also looking into using air injectors?
        and kelv for now sticking with the p8 ecu. . . . no doubt if or wen? my gearbox breaks il also look into aftermarket managment.
          p8 is a cracking ecu fella
          with the chip, it depends what msd have done with it as they tend to try and scramble the map so no one else can get into them,
          but dependant where you take it, they would probably start with a new chip and go from there
            pmd j1mbo and thanks again pal.
              hi gaz me and mark are off to harveys tomorrow ill let you know how we get on see you tomorrow jimbo get the kettle on m8
                will do mate, even gonna try an get out of bed early to get it on for ye, but if that fails, see ya half 8
                  were leaving here at 330 think i will have to shit the bed but i will be asleep all the way to you as mark is driving top lad is mark
                    bugger that hopefully worth it though mate
                      sound david pal give me a ring or text during day will keep phone on me- but saying wot ive just typed you are probly in bed asleep now if geting up that early so il text you at some point 2morow.
