cant believe it.. just found why my car let me down for pod....
  • cant believe it.. just found why my car let me down for pod....
    water in the crank shaft sensor connector..... what a joke..
    the day before i changed..
    plugs
    coil pack
    ignition amp..
    water temp senor
    air temp sensor..
    checked the readings on the tps...
    didnt think it would be crank sensor as the engine did run... and i didnt check the connector because i always keep it taped right up in case it leaks... but water must have got through the tape.... i cant believe it i didnt need any parts ive given all those bits back to my friends now..
    bad times..
    Bad luck. But good it wasn't any serious
      at least it was something simple. Taping stuff up can be mixed blessings unless you regularly redo it as youve found out once water spray works its way in it sits there held in by the rest of the tape.
        Wondered where you was
        By the way, reason your old box rattled was a stretched transfer chain and a tooth missing............. just thought you might like to know It's got a new lease of life now though
          oh guess it was the tooth that was the concern?? i hope it works well for you...
            always the way ain't it, crank sensor went on mine but the car would run until warmed up then it'd play up.
              glad it was something simple and nothing to serious
                I too wondered where you were .
                  How's Pete getting on?
                    All good as far as i can tell, just about to shoot up there now to make a little collection
