5 bar map sensor
  • 5 bar map sensor
    What boost do most of you run at 500bhp with a gt30? Will i be needing a 5 bar map sensor or will a 3 bar be enough?
    You will need above 2 bar.
      I run a 5 bar map sensor
        Surely a 3 bar sensor is good for up to 45psi, ( or 3 bar approx?) so would you need a 5 bar one for 75psi? Or have I got the wrong end of the stick?
          Best add it to my already massive shopping list
            A 3 bar map sensor will only do 2 bar positive boost, and 1 bar vacume.
              Next question, ive got a set of 72lb siemens injectors. Will these be ok at 500 or will they be maxing out there duty cycle?
              Should i move onto 83lbs?
                The 72lb will be flat out so I would recomend 83lb.
                  Got a 5bar and lead instock so PM me if you need it!!!
                  BOSCH PARTS 07759984033
                  INJECTOR CLEANING
