Head Bolts
  • Head Bolts
    Need to order a set of head bolts from Frauds (sorry, I mean Fords!) and looking on Micro_cat there are two numbers for the bolts. Anyone any idea which Finis Code is the right one?
    The guy at Fords said I need the engine serial number (thought they went off just the engine numbers itself?)
    Anyway the numbers are
    Finis 1645270 (engine serial numbers YBB0001-YBB6418) and
    Finis 1649117 (engine serial numbers YBB6419- )
    Scouse.
    early heads (3 door) used a smaller (captive) washer under the bolt head
      The car's a Monte BT 1994
      Scouse.
        as Jon said the earlier cars had a smaller washer and the Small Turbo cars had a bigger washer but still doesn't help out with which on is which
        but going by the engine serial numbers you would think that the BT ones are the first code and the ST ones are the second one
          The second Finis code is the one I need. Pre 88 are the 1st code and 89- is the second code.
          Scouse.
