arent cut back blades meant to help turbo spool up quicker? though rally cars had mainly cut back blades.
Completely the opposite .
They increase the boost threshold, but reduce the back-pressure for greater flow (and therefore more bhp and greater reliability at high boost pressures).
So basically the plus side is more power / longevity (at big boost).
The downside is a loss of response / increase in lag.
I seem to remember Vince telling me it was done to protect the blades from hitting the sides of the turbo when they got hot and expanded but in his experiance (and he has a lot) he never seen one fail from it so always felt it was a gimick and not in a good way.
Disclaimer, my memory isn't what it used to be so all of the above could be complete bollocks
Blimey Mike I'd have thought you'd have known what's what with turbos. I learnt my lesson a few years ago on PF when my mis-conception was corrected - straight from the horses mouth, apparently
is that vince from cr turbos? as thats one company i wont be using again
brand new turbo off him last 12 miles with no boost going through it after it seized and he blamed it on my fuelling saying it got to hot, i ended up with 3 turbos from him in the space of 2 months but none was his fault, i could of gone gt 30 and external gate the amount of money he had off me
I've used Vince since the Turboshop days, personally I can't find a bad word to say against him. Something must have been seriously wrong not last longer then 12 miles
i had all brand new turbos, the 1st turbo lasted just under 2k before the seals went 1k of that was running in a brand new engine
he said it was the debris fromnew engine and i should run a filter, ok fair enough
2nd turbo was bought with oil filter, started engine up and my mate said theturbos f knackered, which i said was impossible, took it down the road with noboost as i had just fitted compresssion struts and adj tcas and nothing was set up as tyres hitting arches then, heard a nasty grinding noise and then a big bang, the ex blade had welded itself to the housing i was told
but this was my fuelling that caused this after 12 miles asaying my car ran lean, my car had never ran lean as it was always slightly rich according to my gauges
3rd turbo i bought lasted 4k then stripped the car and sold it on
