I've finally got around to swapping the looms over on the Monte and I need some help with the fuse box connector.
I'm pretty sure this all alarm related so please give me you advise if you can. i have no idea what these wires are for but if someone has a wiring diagram then please help me!
This is the loom to fuse box connector I'm talking about
Question 1. When the Wipac was removed I remember I had to add a earth which is the blue/white strip wire you can see. Not sure If the new loom will need this? Do I just add this earth to the new loom connetor?
This is the replacement loom connector
It has a few wires cut and has a few wires that have been sliced into these that have been cut off
Question 2. This two wires have been cut and there is about a 10inch gap to where the wires continues do I simply patch wires into it to join them up?
Question 3. Do I just tidy up the splices on these three wires
These Questions are propably no brainers but I just wanted to check, part of the problem is I have no idea what these wires are for, I'm guessing they are for the alarm.
Thanks in advance for any help
