Engine turns over but won't start. Helpppppppppppppp
  • Engine turns over but won't start. Helpppppppppppppp
    Hi guys
    As above drove the cossie this morning fine parked up went to drive off couple hours later and nothing.
    Engine turns over but does not fire up I'm thinking it could be fuel not getting through.
    red light appears on far left near temp and clock display the orange and other red light go out
    I loosened fuel return pipe and no petrol was found carnt smell petrol either
    Which fuse is the fuel pump relay fuse and where is it ?
    Before any says yes the car does have petrol in it. LOL
    Cheers for help in advance
    do these cars have a safety cutout? like the saffs in the boot under the spare or maybe by the passenger door?
    BOSCH PARTS 07759984033
    INJECTOR CLEANING
      They certainly do, its in one of the front kickwells, but i cant remember on which side as mines all been moved
        Its in the passenger side, there is a little hole in the kick panel.
        Team S.T.A.M.
          passenger side. Small black box with a red button on it.
            safety cut out on passenger foot well I've checked that and is pressed down when it cuts in it comes up
              franco are you talking about your black boyfriend or the car?
              INJECTOR CLEANING
                so must be a fuse then..no idea where it is though...on a saff its passenger side under glovebox.
                INJECTOR CLEANING
                  just tested all fuses with a meter and there all fine. What about heavy duty fuses infront of battery in a cover type thing ?
                    this is what hapend to mine, thinks mines the relay but havnt looked any further into it,put a live to the red/blue wire behind the bumper its the fuel pump live, see if pump runs and car starts
                    1/4 mile 9.52 @ 146mph so far
                      if no fuel came out the return then its got to be fuel wiring fuse or relay that should be together (on saffs they are)
                      INJECTOR CLEANING
                        will get a new fuel relay tommrow and try it put a test on it and come back as if something isn't working. Thanks for your help and will let you guys know of the out come
                          Good news guys the cars working again
                          all it was is a loose realy
                          cleaned the connections plugged it back in and yahoo the cossies lives
                          thanks once again for all your ideas
