909 top mount sleeve
  • 909 top mount sleeve
    Has anyone got a link or know were i can get these 909 top mount sleeve,s
    Paul
    I posted a link in your other thread matey, that's got mk1/2 bilsteins so I think the thread should be the same? My top mounts had a two piece sleeve in them though. The bottom part actually spaces the mount up a few mm, so you may need those instead? Give Fred Crawford a ring 028 2827 3877 he may be able to help.
      Cheers Mate
        I`m also ater some, but on bilstein grp4 for mk1/2 is not same thread. The hole in my top mounts bearing is 22mm or maybe it`s inc, but on many others top mounts, the hole is 20mm
          Mine are 22m/m & thread 12m/m x 1.25
            All sorted spoke to Fred & he was very helpful going to machine some bush up my self Cheers Paul RS
              Good stuff, least you got sorted!
                I haven`t got my bilstein b6 dampers yet, so don`t no which thread it is, but maybe like oe??
                Maybe i have to machine some too.
                Is this the same as yours?
                  was he making mad noises lol, he is nut is fred but very helpful.
                  Thanks Mark.
                  NORRISMOTORSPORT 01773836274
                  WWW.NI-FORDS.CO.UK
                    Yes mate these are same as mine
                      Cool, are you making te sleev in two pices then? I can make some up at work, just have to get some material. What kind of dampers do you have?
                        No mate i have just turned a 1 piece sleeve witch is a nice push fit in to the bearing & drilled to fit over the thread on the strut (not threading the sleeve)
                        Paul
                          Oki, thats easier to make on like that, but will the damper nuts go as long down on threads as oe?
                            Should do mate i will keep you updated
                              Thanks mate, like to se how yours became
