-8 from tank to pumps or even -10 is better as you want a large bore as its gravity fed, then from pumps to fuel rail -6 so you get good pressure in the lines but -8 is also fine as ultimately your fuel reg if working correctly will keep pressure between the fuel rail and pumps at 3 bar or 3.5 bar at idle regardless of hose bore, then -6 back to tank or swirl pot if your using one,
