Hi there, any one who can give some advice?
Basically over the past few times i have used the cos its gettin a worse vibration, i've had all the wheels balanced, checked the discs with a DTI and had a general look over all the drive and prop shafts.
It only seems to be when hard accelerating though in higher rpm. Its gettin worse everytime i drive it as well but cant think what it can be.
I've also jacked up the engine but the car went with it so i guess its not engine mounts either!!
27/4/11 - All the driveshafts have been off and are all perfect, 2 new engine mounts, and front Prop has also been off and been checked over but nothing needed to be sorted, it was all well.
Only thing I have noticed is there seems to be a little bit of play in the mid support for the rear prop, and maybe I should change the gearbox mount as well.
