help im beat !!!! cant get pauls car to run SORTED CHEERS ALL
  • help im beat !!!! cant get pauls car to run SORTED CHEERS ALL
    as some may know im putting pauls car back together anyhow almost there but it wont run it fires on initial crank but then nothing seems like its flooding ive been on it for 2 solid days now
    changed ecu
    chip
    injectors
    loom
    ign amp
    fuse box
    ps it sounds like ign timing is out when it cranks over but its not sounds advanced
    any ideas pls
    Oh bugger .............. better call the AA lol
    Gonna be summat simple............ you know it is Leave it alone for a day then i bet it will come to you
      Crank Sensor?
        Crank Sensor?
        i was thinking that !! give it a wiggle or a clean or try another.
        could it be the battery after what happened
          Is it back on a dizzy now?
            Sounds like fuel pressure to me? Is the fuel pump feed dropping out or something?
            Cheers, Kev.
              As Si asked is it Back on dizzy?
              Andy
                Look at the obvious is,s not times 180 out is it,or is the phase sensor fuked,
                cheeRS stu
                  it's back on dizzy and all timing is cock on
                  OH FUCK WHAT WAS THAT NOISE
                    Do you have spark and fuel getting to the injectors?
                      Standard or aftermarket alarm? Whip an injector out to see what's its doing when turning over.
                      Andy
                        Thats what im thinking, had a problem like this before with one and it turned out to be the fuel pressure reg, if you held the rubber fuel hose off the rail and kinked it it would tick over as soon as you let go it would stall.
                        Team S.T.A.M.
                          it's a clifford alarm and we have fuel pressure at the rail but back at it first thing in the morning
                            dodgy cat maybe ?? i would try my tried and tested method of dragging it up the road and see if it will go too
                              Fuel pipes on the car to rail round the wrong way,
                              Another thing to check pull injector rail off put cups under injectors and crank engine over and see what the fuel is doing.
