Iv got birba in mine but the connector to the tacho is broken from the plasma dial itself.U cant solder back the connector to the dial because it has no metal in it,is there anyway to solve this? iv got a little shine from the speedo and then we tried to fix it but then i got nothing,then it was perfect for 1 sec now its black again If the connctor to the tacho doesnt work is the rest suppose to work??
Repair dials?
I think your only option is to replace the el material if there is no where left to solder to, have you tried carefully scraping away top and bottom of material where connecter broken off? The other dials should still light unless you have shorted out the inverter whilst trying to fix rev counter. Cheers Brendan
Originally posted by cozzed View PostI think your only option is to replace the el material if there is no where left to solder to, have you tried carefully scraping away top and bottom of material where connecter broken off? The other dials should still light unless you have shorted out the inverter whilst trying to fix rev counter. Cheers Brendan
The speedo could be shorting out causing the dials to dim or go out ( voltage drop) , are they new or been fitted a while. You can replace the material , as I have done on Georgies birba speedo. Have you tried disconnecting the speedo and does the fuel/temp guage light up ok?
Originally posted by cozzed View PostThe speedo could be shorting out causing the dials to dim or go out ( voltage drop) , are they new or been fitted a while. You can replace the material , as I have done on Georgies birba speedo. Have you tried disconnecting the speedo and does the fuel/temp guage light up ok?
