brake fluid and gearbox fluid
  • brake fluid and gearbox fluid
    right then guys i have ap set up on the front and standard calipers on the rear so when coming to bleed with new fluid what do i use and do i have to do all 4 calipers as i have only took rear calipers off?also what gearbox fluid do i use as i have got standard box and car is running on stage 1 at about 270-275 the box is out at the moment but hoping to get all back together this weekend fingers crossed,also how much brake fluid and gearbox fluid will i need aswell and what make for each and grade
    any good quality dot 4 braking fluid will be more than upto the job. You would get away with bleeding just the rears but if the fluid hasnt been replaced recently then it would make sense to bleed the fronts and flush all the old stuff out so youve also changed the fluid so its good for a while.
      Buy a one man bleed kit, awesome and easy to use Castrol SRF (Available through Ickle Rimburn) is possibly the best stuff if you do track days as well. As Warren said Dot 4 will be fine otherwise
        thanks guys i will get some this week then
          gearbox oil and transmission fluid i want to replace as i lost all the transmission fluid when me and dunc took gearbox out so what and where do i get from and how much,also i have seen comma mt 75 gerabox oil which is the same spec as what is in the ford manual would this be ok or go for something else your thoughts please guys
