fitting rear gaz coilovers
  • fitting rear gaz coilovers
    as above when coming round to fit these do you have to put your original lower arm spring back on aswell or is it just the bump stop and coilover?
    Set up does away with the normal spring mate.
      like this mate
      no std spring
        ok chaps thanks for info
          You may also have to adjust the bottom of the inner arch with a large hammer to stop the spring catching.
            hi neil done this already mate thanks
