rear braided brake lines
  • rear braided brake lines
    as above what end goes onto brake pipe cos one end the thread is shorter than the other end also the same for going onto caliper and where do you fit the washer? and what point ie hose to pipe or hose to caliper
    take the ford one out and compare-
      ok will have a look
        Is this the same problem that Paul had, I remember him saying he had problems with fluid leaks on the back. I'm interested because I'll be doing this soon too.
          you normally fit the convex end in the caliper,unless the hoses are a universal fit then you may need copper sealing washers on it
