what conrods for 500hp
  • what conrods for 500hp
    hello friends ?what conrods you use for your road cars 500+ forged conrods ..fardon? arrow ? dp ? i hear tha arrow is the best ..or any other forged con rods can be handle that power ..of course arp bolts ..cost ?i see fardon are very expensive .
    Standard rods are fine at this power level, unless you want to rev it high?
      I use the pec steel rod and cosworth piston setup on most YB builds now days. Not worth risking the engine for the sake of decent rods if your trying to get loads of power.
        7500 7700 rpm
          If that was my engine at 7500 I'd use a polished beam standard rod with mahle pistons
          That combination has been bullet proof for years
          However, a longer than standard rod is only going to be better and the price of a good quality forged piston and h section rod nowadays is ridiculous and may be worth going for like jano says
          The cosworth pec pistons look good
            i like mahle a lot .but i prefer for 350 + engine ..500+plus will be better with forged pistons as i know .and the conrods can be good for big power but maybe not for long ..depense the boost gt3071 2 bar ..
              a gt3071 at 2bar wont quite make 500bhp
              We have done plenty of 545/550 bhp engines on polished beam std rods and mahles, they're very very good
                what cams and ports .ecu compresion ratio?swedish inlet throttle body mm?
                  We tend to stick to pectel management although webber is very good
                  We have our own design inlet and use a standard sized throttle body as these are good for over 700bhp
                    put picture of the inlet .is like swedish ?what about the flow did you measure tha 4 cylider .is it pretty good ?
                      It is very good and like is aid has made over 700bhp on our engines, it first straight into the car and lines up with a pro alloy rs500 style intercooler (or any other rs500 style cooler I imagine)
                        its pretty nice ..do you sale inlets like that .but with 70 mm throttle body inlet ?
                          We do sell them yes I will find out for you about 70mm throttle body and let you know in the morning
                            send pm
                              also i see you have a exaust manifold with external ..any photo of that ?
