How much is one worth? Done approx 10000 miles.
Scs ut t38
Originally posted by Richie View PostHow much is one worth? Done approx 10000 miles.
Some questions for you, based of the fact that I have an Es Cos with the same turbo fitted and the car drives very well.
What are your reasons for wanting to sell the turbo?
What boost are you running?
What boost control do you have?
Has your car been live mapped on that turbo?
Have no need for it now as KA is on a T34 and the Escos is going GT30/35.
I had it live mapped it the Sierra on Siemens/Swedish Inlet with air injectors. Peaked at 32 psi and held 26.
It was maybe a little laggy if 'caught' in the wrong gear, but it was on an essentially bog standard engine.
Your boost is good, midrange peak of 32 psi tailing away to 26 psi is ideal (as set up on my car by Karl Norris), air injectors are also good, as long as they are correctly dyno / live mapped.
The big plenum I would not have used (standard is better).
With the correct spec cams, it's possible to get 450 BHP with 420 ft/lbs torque. Power delivery is slightly "lazy" but very smooth.
Originally posted by dunccoss View PostDon't think you will see any way near 400lbft as mine didn't and infact felt lazy to me compared to the t34/63
Plus bills car was on different gearing and 17 inch rims which helped it out big time against standard gearing and 18 icy rims
Originally posted by L8 ECU View PostOK, my findings based on the old Billabong T38 car that I've owned for a couple of years.........may help you to sell your turbo.
Yeah when i took it to MSD, Stu asked why the swedish...........simple, it looks better
