Hoping someone can help me here. Modded my car to run wasted spark using the P8 onboard wasted spark driver - no MSD baby board. At the same time I switched the rev counter for one from an RS2000 as the consensus was that these worked correctly without any other mods. I've used an MSD wasted spark loom which I had to mod slightly as their loom connects the rev counter wire to pin 21 of the ecu - which provides a rev counter signal from their baby board. I connectwd this wire instead to one side of the coil pack.
Problem is that the rev counter appears to show the right revs at idle, but it never shows more than about 2500rpm irrespective of how mamy revs the engines doing
. It's also really sluggish to move if you blip the throttle. Should I have connected the rev counter wire to the ignition amp drive signal from the ecu rather than the coil negative (ie to pin 3 rather than pin 1of one of the ignition amps)? Or is there something else I need to do?
Dave
Dave
