Georgie,
From circlip to circlip that hold on the uv joints the Cosworth ones are 350mm.
Early GP A cars ran 4x4 Granada ones which were 365mm clip to clip. That's how I know the measurements. I haven't got the lengths from end to end, just circlip to circlip.
Hope that helps.
Georgie,
Measuring complete shafts can be quite hard as there can be a lot of plunge in and out. The UV's are the same , its the shaft that has different lengths. If you hold an XR4x4 and a Cosworth shaft next to one another it could be hard to distinguish the difference I would guess.I have never seen an XR4x4 shaft so I'm not sure just what difference in length there is and if it is obvious to see.
If he would measure the shaft without the joints that would help, but I don't think he will do that for you. It wouldn't be worth it for him.
It was over a year ago that I got them I was told they were genuine Escos ones but you can't trust some people
not saying i dont trust you just checking as i need there before i had a spare set of front drive shafts told they was escos ones and when i went to use them they was xr4x4
I'm saying i'm not taking the ebayers word for it which is why we need to check-don't want you to have them if they are not the correct ones.
