Pic needed.....Jacko? Anyone?
  • Tech Question - Pic needed.....Jacko? Anyone?
    Has anyone got a picture of where the steering column goes through the bulk head? I seem to have the triangular shaped column (10x10x10mm) going through an elongated hole about 40x25mm. Looks proper dodgy....could be why my steering is so sh1t. Should there be a bearing or gromit or something there?
    phone > 07969 182540
    Boing
      it should have a rubber ring i think on the engine side with a metal cover on it on the bulk head. then theres a plastic bush on the triangle column that slides into all that, if my steering wheel is moved on the adjuster the bush comes out and i have to push it back in bit of a shit design so i just never move it
        Hmmmm I'll look tonight, cheers. It just looks like a big hole!
          only pic i have just now
            in the bulkhead hole you should have
            big rubber grommit, inside this is a plastic ring then inside this is a plastic cylinder with a trangle in middle for coloum to sit in, take a look in engine bay to see if you have pushed the sterring colom to far and push the grommit out lol
            a complete bush kit is about £5 from ford
                I think I have pushed it too far, do you know part number for bush kit?
                My Ford dealer don't even know what a Cosworth is!!
                  This is all i have till i get home as have more with the steering column in.
                    That would be splendid!
                      only ones i have
                        Legendary, cheers!
