Inlet manifold strip down.
  • Tech Question - Inlet manifold strip down.
    Going to do this sometime the next couple of weeks to replace the gaskets.
    How long should it take roughly??
    Any knacks or tricks i need to know or is it as simple as the manual claims by just unbolting everything??
    simple mate
    boost hoses off
    disconnect wiring
    either disconnect fuel lines or take rail and injectors out complete
    undo bracket on engine mount if it has one goes to throttle body
    undo plenum cover bolts and remove plenum
    undo 4 nuts on underside of inlet then remove top bolts
      will i need new seals for the injectors then??
        no mate
          ahh ok easy peasy then!!
            the underside nuts are easy enough to reach??
              yes once the plenum cover is off, couple can be a pain becuae of kidney box and dipstick tube but not to bad
                ahh that be why the manual says to unbolt dipstick tube and move it out the way.
                  im doing the same mate any idea what the torque setting is for the bolts that go from inlet manifold to head please.
