car spluttering
  • car spluttering
    my mates escos has a major problem wen it comes on boost underload it splutters real bad, we chamged plugs and gapped them down, its a big turbo car. tried 2 sets of plugs and changed boost but problem still same. had it on rollers and fuel and afrs are ok so is it electric fault thats how it feels. justin is poping over munday to have a look and try few things but is ther anythn else wot cud caues this i can chek 2morow as my mate is pissed of with car now.
    Try map sensor
      did think cud be that fella, its ok wen car is first started and ran but wen it warms up it get worse and almost undrievabel
        Fuel supply, check to see your getting good charge to the battery too
        Work Hard, Play Harder
          Is it on a dizzy or coil pack' could be leads breaking down or dizzy or the coil pack
            Good call, I had a lead split just by the plug years ago which only started to misfire when the car was hot tiny little split
              warren fuel supply is spot on had it checked today on rollers, car is on standard ignition and have noticed a kind of mark down the white part of spark plug wot cud posebliy mean a lead has broke down if gets hot? got to get it fixed its doin our heads in now.
                gaz feel free to take some parts off my car if you's want
                  thanks fella apereciate that. wil ring you in ten mins.
                    i had the same sort of problem in my monte, in 1st and 2nd gear it miss fired like anything then 3rd on it flew with no problems. then a week later it was misfiring in every gear and just wouldnt go...
                    in the end i traced it back to a dodgy injector plug, the plug was falling apart and wasnt making a good conection on the injector...
                    might help, worth having a look gaz..
                      Inner wing plugs gaz, forever cutting and jointing these on escos
                        tried to ring ya back 2day mate, there are a fair few wires and bits and bobs wich have been taped up on iner wings.
                          will chek these also matey thanks. its bein a pain but we will sort it somehow- carnt let an old ford beat us ha.
                            No missed calls bud! Probs my Poxy phone!
                              ok young jedi will let ya off just this time ha, lets have ya best on wot to check and eliminate, need get this car fixed for my mate.
