Fire!!
  • Fire!!
    On the way home from work today and the Escos caught fire!!! It looked like the battery cables had shorted out...............loads of smoke, so pulled over as the car was juddering a lot. Lifted the bonnet and FLAMES coming from the cables next to bettery!!
    Luckily enough I got them extinquised in time before she actually "went up". Did manage to limp home as I wasn't too far away and turned the engine off, lifted the bonnet to check on exactly how much damage there was.
    All the wires going to the little fuse box had melted and the main wire from the positive side of battery to the little fuse box also got cremated
    Had a go at re-wiring it all, but kept getting the wires (I think they feed the heated screen) as an "earth" instead of "live" when connected to the battery, so was shorting out all the time.
    Checked the starter motor's wires and all seemed OK and then I thought, don't let it be the fusebox!!
    I had no dash lights, heater blower or ignition Anyway took the fusebox down to see if there was any damage, but nothing seemed to have had a problem!
    I've since re-wired the small fusebox and main feed to it from the battery and then checked the polarity of all the wires. All seems OK now and have since started the car, alternator's working (thank God ) and it seems so is everything else.
    No idea why when I tested the small fusebox wires they were all coming back as negative polarity
    Another day in the ownership of the Ford Escort RS Cosworth!!
    Scouse.
    thats not good mate, didnt the same thing happen to paul earlier this year?
    battery hit the bonnet?
      I even went to Euro Carparts for an 097 (flat posted battery) and they said they don't stock them anymore. I'm sure someone on here bought one from them a few weeks ago?
      I need to change the battery sharpish!! I HATE ROUND POST BATTERIES!!!!
      Scouse.
        That happened to Paul so maybe he can point you in the right direction
          square or round post battery
          OH FUCK WHAT WAS THAT NOISE
            Read 2 up!
            Scouse.
              get a square post battery straight away and also just make sure the cover or something suitable is over the battery to stop it from happening again
                Scouse.
                  there have been sooo many people that have made this mistake
                    Gutted for you mate Did you use the adapters or proper round terminal connectors?
                      Quite a few had this happen
                      Square posts ones are available, someone bought one on here a few weeks ago I read.
                        Got round post terminals on my battery, Got an adaptor kit from local motor factors and no probs. Got a plastic battery cover from fords to keep it all covered up..
                          shame to hear but you were lucky really.
                            I cant believe that this keeps on happening. All round post battery escort owners out there please please check your cars over and if in doubt buy a plastic battery cover from fords for a tenner or so,this could save your car for you. Square posts are available too so if you can swap please swap.
                            Glad you got away with it this time scouse
                              do you need to have the battery covered up then as mine hasnt got a cover?
