Originally posted by Rolls
View Post
Top mounts
Has to really be with coilovers, purely from the point of view that the mounting point is changed, so a fixed spring can't allow for this. You "could" get round this by making the mount position the same as it is, but this may mean fabrication work to the turrets or putting a spacer in if it needs lowering.Mike Rainbird
You are a star RonnieOriginally posted by ronnie amis View PostI'd be more than happy to take mine off if they could be copied quick enough
Just make sure you make them out of good grade material
Originally posted by neil a View PostRonnie are yours still mounted the original way with bolts from underneath holding the top mount in place or did you through bolt them?
They are bolted from underneath Neil. They can't be bolted through as they slide and would hit the bolts
Kleers.com 15% discount code 'RON15' for a discount on all cleaning products
