whats the best way of removing underseal / body schutz ???
  • Tech Question - whats the best way of removing underseal / body schutz ???
    as above
    i,m going to be removing all the black underseal on the floor of my car over the next few weeks back to the ford original sealer
    whats the best way of doing it ?
    i removed a bit with petrol and it can of easy enough but is going to take ages and ended up still having to wash it all of with a scotch pad and thinners
    also do one at work and used thinners and petrol then a hot steam cleaner but still took ages
    is there anything that can be applied to it to soften it so it just steam cleans of easy ?
    thanks gibby
    i would say no gibby, it's just trial an error mate petrol or thinners is your best bet but you could try a wire brush on a drill
      Do not time doing it. Find a set of outdoor 2 post ramps. use a powerful steam hot wash power washer. With tfr.
      A member on here did mine and it took about and hour and I had no underseal left to do myself.
      I wouldn't of done the underside if it wasn't for that as I hate cleaning underseal of.
        also used the wire wheel on the drill on the other one i just done , it just came of the car and stuck to me tho
        not got an outside 2 post but will get it up to a good hieght and try TFR
        cheers
          Steam clean is the best way i found and you get every thing off it back to the nice clean original under seal .Have tried every thing else this is the best way!!!!
            Was looking through google 'how to remove underseal' and this pop'd up lol you still thinking about doing it?let me know how you go on if you did it??
              I done mine at the weekend there
              Never used anything apart from a steam cleaner and the heat just peeled all the wax oil of it back to the factory sealer with overspray look
