Can you get them for the escort Cosworth?
Seat bolsters
Mark,try capital seating,Bristol.Here's the linky.
http://www.google.co.uk/url?sa=t&rct...feuLDlmooOzVbw
Thanks.Lee.
them in the link look like what you will find under a a sierra or escort rs turbo recaro chair, the way my mate does repairs on recaro chairs that need the foam repairing is to remove the damaged loose material and glue using special trimmers glue new foam to the hole,then the foam is shaped back to how the contours of the foam originally were,bit like filling a dent with filler if you like,if your good you can't see the repair. and as he has been doing this with recaro chairs for like 30 years and nobody has ever seen the repair under the new material i'd say that makes it a ideal way to sort the problem.
also them diagphrams under yer arse, he uses 2 to make 1 if that makes sense when they break due to heavy arses busting them,he did one for me last year and it was like a new chair after.
You can buy them new from Recaro, I bought 3 - still got 1 spare at home in the garage.Originally posted by COZZFATHER View Postalso them diagphrams under yer arse, he uses 2 to make 1 if that makes sense when they break due to heavy arses busting them,he did one for me last year and it was like a new chair after.
so the bolsters are the same for all the ford recaros?
roy,is the seat fabric you need the same as the 91 4x4 saff dark cloth?if so i have 1.5x1.0m of it that i bought for my saff with two outer bolsters.sigpic
I'll give them a call make sure I get the right ones. Cheers
I had one replaced by capital a fair few years back,unfortunately it was a different shape to the original. This is what made me think the Monte ones are a different shape to the lux.
Maybe worth phoning them to see if they list 2 different part numbers for the escos.
I'm sure from memory,the Monte had more angled items and not more rounded like the lux.
