Autronic SMC ECU
  • General Question - Autronic SMC ECU
    What do you guys think of the Autronic SMC ECU as areplacement fot the standard P8 on a cossy. Do you know anything about them?
    give mark shead a ring hes your man for these i think
      a very good ecu mate no comparision to ford rubbish
        looking at maybe getting something that is mappable here in OZ.
          if you can find someone to map it there you wont go far wrong good ecu mate
            Got Autronics on mine anti lag, launch control should be cheap for you as there Australian
              Use the SM4.
                I'm on sm4, quite easy to use, you can download the soft from there website
                Only bad thing is my cold start is crap, not sure if they are all the same.
                  Tweaking helps having it for a few days when its cold and the 1.09chip is better again.
                    with loads of surge
                      can you upgrade my ecu to a 1.09chip ?
                        Yes, I need to check stock.
                          cheers mark can you pm me the price
                            Im on 1.09 and no problem whit a cold start at 0 dgr C whit a proper map.
                            WWW.COSWORTHCLUBSWEDEN.SE
                            www.jospeed.se
