So after several weeks I still can't get my car to start an run...
A little background; I decided to revert back to the standard management on my ST Escort, when I bought the car it came with an Omex management but I was not happy with the drivability. Anyway I bought and installed all the factory components that goes with the standard management including the ECU. Initially I thought my problem was not having the correct map sensor (hard start and over fueling) but it turns out my problem seems to be the PATS system. When I attempt to start the car and for the few seconds it does run (occasionally), the alarm light flashes. If I am correct my ECU needs to be reprogrammed to match the immobiliser, problem is I'm in the states and the local Ford dealer has no idea what to do nor any of the locksmiths I've contacted.
What are my options? I thought about disabling the system altogether and have the wiring diagram but I not sure what I'm doing and I know how sensitive this type of information is.
Any ideas...?
Any ideas...?
