I am using hubcentric spacers on the front of the fiesta to widen the track
I have the hubcentric spacers and they are the variety that bolt to the original studs then have 4 more studs pressed into the actual spacer that the wheel bolts to
My question is.........What nuts should i use to bolt the spacer to the original studs?
Half nuts? normal full size nuts? nylocs? i cant find anywhere that show a pic or tells what type of nut should be used? the thread i need is M14x1.5
I would feel better if it was a self locking type nut as there gonna be hidden away behind the wheel so not as easy to check as the outer wheel nuts
Marc
Marc
Officially insane!!!
