help with alloy fitment please
  • help with alloy fitment please
    im after some 17" alloys for my berlingo van & wondered if ford alloys fit as there 4 stud as well?....... ie would these fit ebay number...330673927560 thanks
    the pcd is the same at 4x108 but the centre bore is 65.1mm according to my chart where as fords are usually 63.4mm
      thanks mate...
        The centre hole does not line the wheel up it is you studs/nut's when fully tightened up that do that. As ford centre hole is smaller you could get it machined out then the wheel should fit on but it is quite likely they be tucked under the car because of the offset. So unless wheels are cheap not worth hassle.
