Right need some longer wheel studs as mine are to shortGot rondells on at mo but he bolt don't come right through the nutTried a mo on and same thing so how long do they need to be and what size etcBeen lookin on the bay but got lost now
Longer wheel studs
Originally posted by escosgaz View Postcol i wud just ask mike rainbird he supplied mine and theyre spot on m8.sigpic
Wanted some shorter wheel studs for my car as my 65mm ones were too long for my new wheels. Had such long studs as was running 20mm spacers on my OZ Superlegs.
Did a wanted post on here suggesting maybe Mike could help but never got a reply, so buggered off to Ebay and bought a set off there for £21 delivered, 65mm length, and cut them shorter.
They'd be the ideal length for you I expect- get outside and measure up what you need
Link to the ones I bought:
http://www.ebay.co.uk/itm/2806551135...84.m1439.l2649sigpic
Originally posted by Si B View PostWanted some shorter wheel studs for my car as my 65mm ones were too long for my new wheels. Had such long studs as was running 20mm spacers on my OZ Superlegs.
You have my email address and could have PM'd me . I can't read EVERY post and if I see a query aimed at me, I ALWAYS reply .
Anyway, for the OP, you need a MINIMUM of seven full turns of the nuts on the studs. If you have that, then you will be okay. If you have more, then no worries at all, but if you have less, you need longer ones.
When cutting them down, a trick is to put a nut on first and wind it down to the length you want. This allows you to butt the hacksaw up to it to cut straight, as well as when you remove the nut, it will burr over any material so that the factory nuts will go straight on .Mike Rainbird
I haven't got a standard one here to measure, but the two I have are:
Right = 48mm (thread length 28mm)
Left = 65mm (thread length 43mm)Mike Rainbird
Originally posted by Cossie col View PostSo that short one is 8 mm longer than standard if the one on right on your site is 25 mm longerso do you sell the 8 mm longer ones then Mikeif so why aren't they on your web siteMike Rainbird
