Would a gt3071r be any good on this spec
  • Would a gt3071r be any good on this spec
    Hi.lads just want ure thoughts on this please
    200 block 7:2/1 cr
    6 long studs
    Wrc hg
    Bd 14 inlet standard exhaust cam
    Ported and polished head
    Air injectors
    83lbs Siemens
    What's ure thoughts and what sort of power do u think it would make
    200 block 7:2/1 cr
    6 long studs
    Wrc hg
    Air injectors
    83lbs Siemens
    Your spec looks good (I'm not sure about the cams or injectors), but 500 - 520 BHP may be possible.
    See here:
    http://www.escortrscosworth.com/foru...ighlight=vipec
    And here:
    http://passionford.com/forum/general...es-514bhp.html
      As Doug said, spec is good enough so no reason not to go ahead with it.
        The engines is already in a 2wd Saph with a t34 /63 on it, I was goin to buy a gt30 new injectors and remap it
          The 83's should be good enough. Depends what boost you want to run really.
            I'd like between 460 / 500 really so boost would be round 26/30 psi at a guess
              Any reason you go that low in comp?
                Not my choice mate the engine already been built and has done 3k Im going to look at it at the wkend ,
                  I would put another inlet cam, like a BD15/16, if you want 500bhp.
                  But think that would be better to speak with your tuner.
                    There are two different GT3071Rs - Garrett quote the maximum for each at 460 and 480 respectively, with the GTX version being rated at 560bhp. However, I'm not sure what boost this is at, as it doesn't say.
                    http://www.turbobygarrett.com/turbob.../turbochargers (Page 2)
                      TBH, I didn't took a look to the compressor and turbine map...
                      So you are right!
