to fit a mt75 gearbox from a saphire into an escort can you get away with changing the front half of the rear prop to a saphire item or do you have to change the back end off the gearbox casing?
gearbox question??
if you put a saf box in a escos you change the front half of the prop to a saf one with bigger doughnut
and vice versa for saf
its only the rear section between props thats different fronts are same bar different size doughnuts
and the out put flange on the escos box is long and has a different style 3 prong thingy with different bolts
