Is it possible?
I'm curious, has anyone got 9x18's, et20, 245/35's and running Koni's?
Do they fit ok atall?
Just assisted a mate to try and fit his and they just make contact with the base of his shocks, worrying thing is that the wheel nuts were lucky to even get 4 turns on them.
I took the disc off to measure the bell thickness as it looks a bit big to me and it came up at 12.98mm (hence me asking if they are normally 10mm).
If the bells were the correct 10mm thickness then the wheels will only be pulled in even further, therfor making even firmer contact with the base of the shock
Bell thickness would explain why the wheels nuts only get 4 turns.
I personally dot recall anyone running 9" wheels in that size combination without running coilovers!
Anyone able to say any different?
, lots of people driving around with 4-5 threads holding wheels on
