Gear Stick Reverse Lift Broken
  • Gear Stick Reverse Lift Broken
    As in title here is what's left of my reverse lift,
    bits have been falling off for a while, but as you can see it is much worse now!
    Is this easy to replace and were am I going to find the part? What would you call it?
    Is this common? Anyone else had theirs fall apart?
    Gav
    R and B Motorsport www.randbmotorsport.co.uk/shop
    My engine build & bodywork restoration http://www.escortrscosworth.com/foru...ad.php?t=10500
    Pull the gear knob off and you will see the little cable coming up through the gearstick itself.
    Remove the broken leaver, hook the cable onto the new lever as you push it on and thats it.
    As far as I know all mk5/6 escorts have this setup.
      are you supposed to be able to select reverse without the lift ring? My car has the cable not attached to anything yet i can select reverse fine.
        Same thing happened to mine, i got another one and that did the same, so now i have a quickshift B+M shifter to fit that will cure it.
          You're not supposed to so the part on the gearbox cradle that stops you from selecting reverse must be worn or the pin is not all the way in and getting past the "stop".
          Scouse.
            Mine did this a couple of months ago.
            There is a horseshoe washer that holds the cable in position. This sits inside the bit of yours which has broken.
            What you have to do is remove the gearknob. Then remove the centre consule. Turn it upside down whilst attached and cut the tyrap holding the gaiter to the the plastic bit.
            When you get the new one you need to attach the horseshoe to the cable. It's a bit fiddly but I used a set of long nose pliers.
            The Sapphire 4 x 4 one fits fine. I got one off my parts supplier Richie
              thanks for everyone's advice, doesn't sound too bad to sort out if I can get hold of the part!
              Has anyone seen one for sale? ebay / here / ford or anywere else?
              What should I ask for?
                anyone?
                  what type of gear knob have you got, screw on or push on, i have a couple in the workshop
                  1/4 mile 9.52 @ 146mph so far
                    anyone?
                    Gavin, just go to ford and buy a complete new gear lever, they were still available about a year ago when i replaced mine.
                      note sure, although I must have taken it off at some point when I replaced the gaitor.
                      I will check tomorrow.
                      worth a look can you remember how much it was?
                        well let me know, i only have the screw on type but its free, you can repair yours with it if its the push on type
                          I will check it out tomorrow and let you know. Thanks for the offer
                            Yours looks like a push on one to me Gav.
                              its an early homologation model would that make it a push fit?
