who's ready for croft??
  • #31
    Originally posted by Carparts Express View Post
    New pads and discs fitted to my focus yesterday.... Ready for Saturday track sesh
    do you want any salt to rub in to
    • #32
      I am sure the tread says who's ready for croft ?????
      • #33
        lol m8
        • #34
          It's a bit tricky to do the on-road mapping with a gearbox that won't shift up...
          Regarding the starting, if the car has been left for a long period and the battery voltage drops below 11, the T6 ECU won't allow the car to start. I have the same issues with mine if it has been left unused for any long periods and it just needs to be kept on a trickle charger - no big deal (despite Wenny trying to make it into one ).
          Just check the voltage on the Pectel monitor or Stack. If it drops below 11, you'll need to jump start it .
          • #35
            Should it need on the road mapping Mike, thought it was all done on the dyno'd.
            • #36
              Still needs finessing on the road Dave, cant do that if it wont up shift!
              • #37
                It started when he collected it but wouldn't 4 hours later.
                The cold start hasn't been done as far as I'm aware.
                • #38
                  Fair enough.
                  Why has Gaz taken the car back then when it's not finished.
                  The box is on order isn't it, then SCS fit it and then finished the car.
                  Don't know all the facts so don't shoot me down.
                  • #39
                    shame you didn't tell gazza man that before he smashed his laptop up
                    • #40
                      The dyno is only used for the full load mapping, you then need to do ALL the part throttle map in the car (unless there is an identical spec engine that has already had this done, that you can use), along with full load checking in the car as well.
                      This was all done on the way to and from Bruntingthorpe in my car .
                      Regarding the cold starting, you only get the opportunity to do it a couple of times a day. However, I have no idea on the time scales regarding this being done compared to Gaz getting it back?
                      • #41
                        I only saw it just this morning. However, he can always phone me if he wants to find out the whys and wherefores before hand - I'm not his keeper .
                        • #42
                          Fair enough.
                          I believe he wanted to just put it away and sort another gearbox out, so just collected it prior to this happening. I "think" he is now getting the original item fixed though .
                          • #43
                            after the grooming you gave him you would like to though wouldn't yer !!
                            • #44
                              Originally posted by mike rainbird View Post
                              it's a bit tricky to do the on-road mapping with a gearbox that won't shift up...
                              Regarding the starting, if the car has been left for a long period and the battery voltage drops below 11, the t6 ecu won't allow the car to start. I have the same issues with mine if it has been left unused for any long periods and it just needs to be kept on a trickle charger - no big deal (despite wenny trying to make it into one ).
                              Just check the voltage on the pectel monitor or stack. If it drops below 11, you'll need to jump start it .
                              im not making it 1, the amount people who tell me whats happend to them, i wish they would speak up, i think 10.5k is to expensive aswell
                              im allowed my opinion
                              1/4 mile 9.52 @ 146mph so far
                              • #45
                                No one ever speaks up, the amount of people who have had problems with MSD is crazy. Infact I think it's only you, Ginge, and Blacky who rates them
