Dump valve or no dump valve?
  • Dump valve or no dump valve?
    I have been having problems with my car only holding 14psi and I thought it was my wastegate not closing properly, but after looking at the car today I feel like a right fool, my cars dump valve diaphragm has a big burst in it, so I'm hoping when I take the car out again it will be going alot better,?
    My question is should I get a new diaphragm or should I just run a blank? I know it's meant to be bad for your turbo not using a dump valve but how bad is it?
    CheeRS Shaun,
    SCS MAPPED 482 BHP 400 lb ft
    DO AWAY WITH IT I HATE THEM
      i found my car has alot less lag with out the dump valve on
        If you are not running high boost then all will be ok Shaun.
          Because the dump valve was burst im hoping that my car will now go better ?
          CheeRS Shaun,
            24psi ?
            CheeRS Shaun,
              24psi ?
              It will be fine do away with the woooooosssssshhhhhh
                Yeah it'll be fine at 24psi, just stick a bung in it's place.
                  as said, should be fine without it.
                    shaun i dont run one,and same as steve i hate them lol
                    cheeRS stu
                      Mines running peak 32 holding 26 ish I don't have one.
                        Is it not meant to kill the turbo not using 1 tho?
                        CheeRS Shaun,
                          What's the psi of a 100% original small turbo ? As it come from the factory no mods or anything
                            They sound amazing with no dump valve and a cone filter
                              I know mate I live that aswell but just don't want to kill the turbo,?
                              CheeRS Shaun,
