Changing Gear Gator
  • Changing Gear Gator
    Hi guys, so Im going to attempt to change my gear gator this week, as I am toally pants when it comes to doing things like this I wondered if anyone had a step by step guide that even I cant go wrong lol.
    Thanks,
    Ian
    Before you change it mate you'll need a stapler (industrial type) to refit it back into the console.
    1. Remove centre console
    2. Un-staple old gaiter from console
    3. Fit new gaiter and trim as necessary
    4. Refit console
    Scouse.
      Thanks,
      Ian
      Its pretty easy:-
      All you need to do is a couple clips down side of consul each side in footwells, and remove radio and CD player and you will see couple screws then remove the electric windows and boot button and should be couple in there.
      Pop or screw off the knob, suit u sir! and then whole thing will come off!
      looking inside you will see a plastic sleeve with shit loads staples in pop that out and then the gator will probably disintigrate as you pull it! (they are load shite) remove all old staples and snip cable tie from round top.
      then put new one in- try not make it 2 baggy but have enough material there to get it in 2nd and 4th.
      u can set it and keep trying it as u go.
      place plastic sleeve on inside- ensure that its how u want it and staple away- bang plenty in and use heavy duty staple gun! also bang in a new cable tie around top of gator.
      put it all back 2 geva!
      dead easy!
        Brilliant thanks a lot guys.
        I will get stuck into that this week.
        Ian
          be very careful when removing the window switch surround as they snap easily
            Now where would I get a radio removal tool?
            Ford dealers?
              halfords.or i can lend you one if your down this way?
              Thanks Mark.
              NORRISMOTORSPORT 01773836274
              WWW.NI-FORDS.CO.UK
                Get a welding rod and bend it into a "U" shape and make two of them!!
                Scouse.
                  Sweet thanks Mark.
                  Get one tomorrow then!!
                    Thanks,
                    Ian
                    Stinky get some pics up...........i need to do mine
                      Did mine about 8months ago and looks great. Quite easy to do. Once you have the console off.
                      RSOC Member 16886
                      Darren Parker
                      07539-936944
                        It is quite easy to get the gaiter too tight though, so just be a bit careful. Especially if it's an aftermarket one, because they don't give you much spare to play with.
                          Ok guys I will take a few pics of the process.
                          Hope there wont be any of me F'ing and daming lol
                            Quick question:
                            Once I pop the clips off the centre console are the good enough to reuse or would I need new ones?
                            Just want to be ready before I start
                              The clips from the side of the console can be reused if you want.
                              RSOC Member 16886
                              Darren Parker
                              07539-936944
