Pectel
  • Pectel
    Hi
    My knowledge about pectel management is limited...
    So some questions
    1. This should be a T6 right?
    2. This is a pectel controlsystem... What can it? Should the steps 1-8 made a "click"?
    3. Is this a special one?
    4. What's this? How to connec`t?
    5. This is a lambda sensor correct? Special one?
    6. This is for the spark and two amplifiers?
    7. What's that? 1 Ignition and 1 Fuel
    8. How can i connect the Pectelmonitor? i dont have the same big round connector?
    9. Whats that?
    More question follow Have some round connectors i can't assign.
    Thx guys!!!
    ESCOS rebuilt / http://www.escortrscosworth.com/foru...ad.php?t=30193
    10. What's the meaning of Boost Pot? Is that for the air to air injector?
    11. This is the connector of the pectel monitor... but i don't have the same bog connector on the loom?
    Thx
      12. this yellow connector comes from the pectel monitor? for what is it?
        That is a T6 ecu but you need to know the software version to know if it's any good or not
        On the pectel monitor, 1 - 8 show various pages of ecu info like air/fuel/boost/ign data logging etc
        The small yellow plug from the monitor is for a thermocouple to read exhaust gas temperature
        The idle speed control valve you have looks like a mountune version anti lag
        The boost pot on the loom connects to the 12 position boost switch in picture 4
        The lamba sensor is a proper Motorsport item that is quick mil spec connector for a works wiring loom, very expensive when new
          All of it is worth about £500 tops, including that very cheap Lambda plug, I'll give you £500 for it all..........
          Only messin', but all expensive gear. Even that connector for the Lambda is about £300 by itself when new!
            The ignition and fuel buttons look like re sett able circuit breakers that are used instead of fuses
              £375 plus vat new to be precise lol
                www, they've gone up then
                  hi have this infos about the Pectel:
                  T6 Pectel ECU
                  No. PEXT3-46 (i)
                  OIE-500600
                  High / Low Impedance Injectors
                  Pectel Level 3 board
                  8 Injectors
                  Who can check it and can confirm it?
                  Thx guys!!!
                    Give Harvey Gibbs @ SCS a call
                      6. is a coil pack add on loom.
                      7. proper circuit breakers for cossie loom relays.
                      9. looks like a serial data connection. would help if you took photo of the plug not the casing.
                        Harvey? The english people talk to fast on the phones i d'ont understand it
                          Thx Mate
                          I will upload better pics this evening
                            Thx mate
                            is the 1 - 8 a switch? does it "click" on each position? (i hope you understand me )
                              1. Yes that is a t6
                              2. That monitor should click between each position
                              3. That is an anti lag valve
                              4. That is a boost pot and has to be wired into the hairbrush plug
                              5. That sensor is a very expensive NTK wideband which you can use to look after your engines fuelling in conjunction with the t6
                              6. That is a conversion loom for coil pack to a standard car. You will not need this with t6
                              7.as above look like circuit breakers
                              8. Unless your loom has the other CPC plug on you will not be able to connect the monitor
                              9. That is a mapping lead, it goes from a rs232 port on a laptop to the jack plug on the loom
                              10.the boost pot allows you to have four different boost positions
                              11. As above, of your look does not have the plug on you cannot use the monitor.
                              12. That plug on the monitor is offer for egt or a pressure take off if I'm not mistaken for the readout on the monitor.
                              Hope that is of some use. If you need any other help give me a shout, I work with these systems all day every day
