hydraulic clutch reyland kit
  • hydraulic clutch reyland kit
    hi anyone using one of these kits?? , advice on set up do you need to adjust rod length as it seems to push quite a bit of pressure on clutch, i.e when in stationary position pushes hard on arm no freeplay etc
    any advice guys or martin if your on here cheers
    I have just fitted mine and bled it.
    Mine is very light to push. Have you followed the instructions from Martin?
      clutch
      has yours got alot of preload on the clutch arm??
        dont suppose someone can do me a copy of the instructions please
          Me to i will be fitting a hydralic clutch to mine, and instructions would help.
            You both have a PM
              I need one for mine, RWD though
                Originally posted by Paul Cos View Post
                You both have a PM
                cheers m8
