removing side skirts?
  • removing side skirts?
    What's the correct way? Do you remove end cap first,then undo bolts underneath? Do you lift skirts upwards or away from car? Don't wanna break too many clips!
    I removed rivets first then bolts then end cap then sort of pushed sideskirt in and up to try and lift skirt off clips hth
    OH FUCK WHAT WAS THAT NOISE
      Cheers Jim! I'll give that a try...
        yep lift upwards and dont pull it off or you will break all the clips you will prob still break some anyway just not as many
          Yip rivets, all bolts then front cap, lift upwards carefully!
          I was lucky I only broke 2 clips
          Really easy to do and that's a lot coming from me as I'm useless with that type of thing
          Fingers crossed its good under there for you, mine were
          Hope they are as easy to put back on again?
            Cheers guys,ill have them off the weekend,time for a bit of a resto over winter now its off the road. I know I have some issues with the nearside outer,hope its not too bad!
