Question for Puma. warren.
  • Question for Puma. warren.
    Warren some time ago you had a thread and wiring diagram about one push operation of the electric windows. Can you help i would like to do this to me COSSY, if i remember correctly you said you need some relays from a mondeo, are these the ones?
    If so what mondeo can i get them from, and do you still have the wiring diagram for them.
    Cheers mate.
    Tony.
    Info here may also help boyo
    http://www.mirez.co.uk/PassDown.htm
      IMO save the grief just hold your finger on the button for a little longer and all good.
        i can never get on with those,if i try to open the window just a little bit it shoots down to the bottom then if you want to open it all the way and just give a quick press it opens about 3mm
          I have it on both my other cars. Plus i was thinking of incorporating it into the cars alarm so when activated it puls up the windows.
          On my other cars the switches have two ways of working, if you press them down all the way the will go down all the way but if you just press them a little bit they just go down as long as you operate the switch, i think there is like a slight knotch in the switch, which you can over ride to get them down all the way.
            See here: http://www.escortrscosworth.com/foru...ad.php?t=18149
              Cheers, Cosmo and lunes86, copy and paste worked atreat.
                the info ive got is in the thread lunes posted above!
                If you want the windows to stop going down you just press the button again. The temptation the first few times is to push the up button to stop it but you just end up with musical windows if you do that
                  Thanks guys,
