Is it essential to have one on a 650 bhp cossie
Oil cooler
The oe ones not on there it's only got the sandwich plate thereOriginally posted by grcossie View Postuse a termostate one in combination whit the oe modine, then you should be safesigpic
That is going to be rapid mateOriginally posted by cossiedavid View PostNo it's for the one I'm doing over marks it's ment to be the
Engine from hadlands gumball car the one that rolled
would love that in my car
Modine is about the same as a 13rad oil cooler. I have a sandwich plate whit termostate and a 19rad cooler, to be fit in in combination whit modine. Sandwich plate will be mounted between oilfilter arm and oil filter. It`s the same way as Martin Hadland had on his escosOriginally posted by cossiedavid View PostThe oe ones not on there it's only got the sandwich plate there
That's his old millington engine isn't it?
I'm planning on fitting one along with the modline cooler. I'm also going to ditch the filter arm over the engine mount and run a relocated filter.
What I want is a filter with a thermostat in it so it flows through the filter and back to the engine then when it gets up to temp goes through the filter and then through the cooler then back to the engine if that makes sense
