as above i think my discs might be warped ( getting vibration through steering wheel when breaking) even tho i dont do any hard braking ive had my wheels recently balanced and they where all fine, can these be skimmed ok and when i put them back together is the torque setting still the same when tighten up the nuts for the bells
skimming front ap 365mm discs
Mine are also doing the same badly, but was told by the seller they needed to be done, my local machine shop said he'd skim them on his laithe for me, he said its easier to do them still attached to the bell for ease of mounting in the laithe.sigpic
Had very similar problems with mine , but had a proper look at the disc and it tuned out to be part of the pads . When the car was standing for a bit in the wet the pads where sticking to the disc ( rusting on ) and would leave a bit on the disc and cause vibration under braking . Took the discs off and used a wire brush on a air drill to get the surface clean . Hope this helps
Originally posted by adam ant View PostIf I remember they are feredeo pads which came with the discs when I bought them hope this helps, I will have a look at the pads and discs over Xmas time as I have not got much time at the moment
The other thing that can cause this is "disc run-out". This is caused by raised imperfections on the mating faces (either the back of the bell or the hub face). When fitting new brakes to a car (as in new to the car), it is absolutely IMPERATIVE that the hub / bell face is spotlessly clean - the slightest bit of rust build up will tilt the disc fractionally and cause this to be exaggerated at the outer part due to the "leverage" effect - as in a 0.25mm deflection in the middle of the bell can be a several mm deflection at the outer part of a large disc.
Remove the brake discs and clean the faces up so they are perfect (if the hubs are rusty, it's best to remove the wheel studs to do this). Proper Preperation Prevents Piss Poor Performance .Mike Rainbird
